19-01-2023, 12:41
Hi - am finally getting around to compiling the software for the wireless display and keep running into issues. Just wondering if I have the basic setup right ? I am using Arduino IDE 2.0.3. I have set the board to LOLIN (WEMOS) D1 R2 and mini. I believe I have installed the libraries correctly. Last part of the compile messages are :-
Any advice appreciated
Using library EEPROM at version 1.0 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\EEPROM
Using library TFT_eSPI at version 2.3.70 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\TFT_eSPI-master
Using library SPI at version 1.0 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\SPI
Using library Timezone at version 1.2.2 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\Timezone
Using library Time at version 1.6 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\Time-master
Using library TFT_eFEX at version 0.0.5 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\TFT_eFEX-0.0.5
Using library JPEGDecoder at version 1.8.1 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\JPEGDecoder-1.8.1
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266WiFi
Using library ESP8266mDNS at version 1.2 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266mDNS
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266WebServer
Using library ESP8266HTTPClient at version 1.2 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\ESP8266HTTPClient
Using library ArduinoOTA at version 1.0 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\ArduinoOTA
Using library RadioHead at version 1.119 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\RadioHead_v1.119
Using library Wire at version 1.0 in folder: C:\Users\spenc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1\libraries\Wire
Using library Adafruit HTU21DF Library at version 1.0.1 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\Adafruit_HTU21DF
Using library SHT21-master in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\SHT21-master (legacy)
Using library Adafruit SHT31 Library at version 1.0.0 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\Adafruit_SHT31
Using library BME280 at version 3.0.0 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\BME280-3.0.0
Using library ArduinoJson at version 6.17.2 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\ArduinoJson-6.x
Using library ESP_EEPROM at version 2.1.1 in folder: C:\Users\spenc\OneDrive\Petes Documents\Arduino\libraries\ESP_EEPROM-2.1.1
exit status 1
Compilation error: exit status 1Any advice appreciated
