Threads: 66
Country:
I am getting random rainfall readings on my Rx recently when we have had no rain. This morning I see 2.6mm, and it has only started since the latest software updates (build 7 and 8)
Has anything changed in the Tx software recently as I have not updated it for about two months and am running v6_b00? (I am unsure of the build number)
Threads: 337
Country:
Arduino IDE version?
Do you have any log when those values appear?
Threads: 337
Country:
I think that there is no reason to suspect of any problem with the rain routines, which haven't changed for years. I'm also not experimenting any problem with the rain readings on any of my receivers. However, and due to some recent questions, I suggest you to use Arduino IDE 1.8.4
There is available a new software release for the Pro2 PLUS (published today v7.0 b009) which was been tested with Arduino IDE 1.8.6 too.
Sometimes, very high winds may cause the rain bouquet to bounce, but not likely it bounced so many times to reach a value of 2.6mm.
Do you have any web address where I can watch the rain graphics?
Threads: 22
Weather Station: Wetterstation Engolling
Country:
Hi Barrow4491,
always take into account that is also could be a hardware problem. Once I was coding for hours to find out at the end, that my rain gauge had a problem.
Threads: 66
Country:
I have compiled with 1.8.4 and uploaded with no issues. I will have to wait until tomorrow at 9 am to clear the current reading and see what happens then
