Screen saver issue
I have just upgraded the Rx software on my new Pro2 Plus system and all was OK until the screen saver activates, and then the date and time displayed changes to Sunday 02-01-2067 and the time changes to 3 hours earlier.
Touch the screen saver and the date on the information display has changed too.
Interesting... I just loaded the latest version release RX code onto one of my Pro2+ RX boards this afternoon, and its back at the office. So I'll let you know in the morning if I'm seeing the same behavior... Cheers Jim...
(08-02-2017, 09:10)Wizza Wrote:  Interesting...  I just loaded the latest version release RX code onto one of my Pro2+ RX boards this afternoon, and its back at the office.  So I'll let you know in the morning if I'm seeing the same behavior...  Cheers Jim...
Thanks Mark,
I didn't notice it in the earlier version
PS the clock does not run either and It is not connected to CumulusMX, just Wunderground
Hhmm.. I thought I saw my clock running. You mention that your clock isn't running..? Is the RTC module in a socket..? Does it look seated right..? Is it in the right way...??? Also, next to the clock, do you see the little green dot, indicating that NTP has connected ok..? Also, is your wifi network online and running ok..? And your in range of wifi signal..? Something certainly not sounding right Jim.... I'll check mine in the morning...
Mark R
(08-02-2017, 09:23)Barrow4491 Wrote:  PS the clock does not run either and It is not connected to CumulusMX, just Wunderground
Hi Jim
The described issue is not related with the screen saver, but with the WU upload.
We are aware of this situation since 1/2/2017, and it seems to no affect all systems but just systems in some country's. It's possible that WU have changed something on his servers, because the WU upload function worked for months and stopped working on several systems exactly on the same day at the same hour.
We are working on it. As a temporary fix, for the time and date change to 2067, just disable the WU upload function.
Here, in Portugal, WU upload have stopped to work on 1/2/2017, and yesterday it started to work again.
Anyway, we already have done some changes on the code to prevent that the problems with the WU upload will affect the time and date functions.
Hi Jim
Anyway, we already have done some changes on the code to prevent that problems with the WU upload will affect the time and date functions.
Werk
Thanks for that. Is the colon on the clock on the Rx supposed to flash as it does on the WD units?
Hi Jim
I have just uploaded the latest  Pro2 Plus software (V2_b019) and I cannot get the NTP light to go green as it has been before but the time appears to be correct. Is the colon supposed to flash  on the clock and screen saver (mine doesn't)
According to my router the wi fi is ok.
I have not not enabled the wunderground upload as yet, due to the issues you mentioned.
I have been running my 5.1 Rx connected to Cumulus MX and WU but this seems to have stopped uploading as my weather station is "not reporting". It has been working fine for a long time until now.
Do you know of any issues?
Quote:I have just uploaded the latest  Pro2 Plus software (V2_b019) and I cannot get the NTP light to go green as it has been before but the time appears to be correct.
Disconnect the power, wait a minute or so, and connect it again...
Also check the NTP server in your configurable settings.
Quote:Is the colon supposed to flash  on the clock and screen saver (mine doesn't)
No, the colon is not supposed to flash.
Quote:I have been running my 5.1 Rx connected to Cumulus MX and WU but this seems to have stopped uploading as my weather station is "not reporting". It has been working fine for a long time until now.
If even from Cumulus your WU weather station is "not reporting" maybe there are a problem with the WU servers.
An important advice: If you are upload to just one WU weather station, never keep the WU upload function active on Cumulus and on the Pro2 PLUS2 at the same. You risk to be blocked.
Quote:I have not not enabled the wunderground upload as yet, due to the issues you mentioned.
The issue with the date and time that happened when for some reason the WU upload failed, was solved in the latest release.
May or may not have been an issue from Australia, but I can confirm WU activated on Pro 2 Plus here with no issues. I have only tried on version 1.0 b018.
I have tried and checked all things mentioned by yourself to no avail so I have attached my config file in case I am missing something.
My WU is working again via Cumulus MX on my old receiver. (I note your advice re sending from two RX units simultaneously.)
My choice is to use the Pro Plus if  I can get it to work
//  WeatherDuino Pro2 PLUS - Version: 1.0 b017
//  Start of user configurable options
//   Define ID's for this weather station
#define Station_ID   0xA1    // Station_ID, use the same value in all TX units
#define Relay_ID     0xA3    // Relay_ID,   use the same value in all WD units
//   Define your Weather Station location
#define LATITUDE      -19    // Put here your Station latitude in tenths of degrees North
#define LONGITUDE     146    // Put here your Station longitude in tenths of degrees (minus for West)
#define ELEVATION     55    // Put here your Station height above sea level in Meters
//   Define rules for Auto Summer Time Display, and clock adjustment
// TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660};    //UTC + 11 hours
// TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600};    //UTC + 10 hours
// Timezone myTZ(aEDT, aEST);
TimeChangeRule aEDT = {"AEST", First, Sun, Oct, 2, 600};   //Qls summer time GMT + 10
 Timezone myTZ(aEDT, aEDT);
//   Define Roll Over Hour for Meteorological Day
#define MeteoDay_HStart 9    // Use values from 0 to 23
//   Define your Display type
#define DisplayType       3   // 1= LCD 20x4, 3= TFT 320x240 ILI9341
//   Define Display Backlight TimeOut
const byte  BackLight_Timeout =   10;   // Timeout for display backlight in minutes (1 to 255). 0 = Always ON
#define Use_ScreenSaver           1    // Instead of turn off TFT backlight show a big clock screen. 0= No, 1= Yes
//   Define data display units
#define Date_Time_Format 0     // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd
byte Temp_Display_Unit = 0;    // 0 for ºC, 1 for ºF
byte ATM_Display_Unit  = 0;    // 0 for mBar, 1 for inHg
byte Rain_Display_Unit = 0;    // no setting, always mm
byte Wind_Display_Unit = 3;    // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots
//   Define the type of your Barometric Pressure Sensor
#define Barometric_Sensor  0   // 0= BME280, 1= BMP280 2= BMP085 / BMP180
//   Define the type of your inside Temperature / Humidity Sensor
#define InsideTH_Sensor  0   // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31
//   Fine adjusts for Inside Temperature and Barometer
const int   TemperaturaInt_offset =   0;   // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC)
const float pressure_offset       =   0;   // Pressure Fine Adjust in mB
//   Define the type of your outside Temperature / Humidity Sensor
#define MainOutTH_Sensor 0   // 0 for sensor type SHT31, SHT21 or HTU21D, 1 for sensor type SHT1x or DHT22
//   Define Wind Speed and Wind Gust resolution
// This setting only have effect when the software is used in Davis VP emulation mode
#define VP2_WindRes     0    // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h
                             // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h
                             // If set to 0, system uses Standard Davis 1 mph wind resolution.
//   Define use of Wind Gust Spike prevention routines (mostly for FO anemometers)
#define WindSpikeControl 1   // 0= Disable, 1= Enable method 1, 2= Enable method 2
//   Define the source of your main outside sensors
// ---- If you have all the sensors connected to only one TX board, always select Unit 0 as source
#define TH_OutUnit       0   // 0 for Temp/Hum sensor connected to TX_Unit 0, 1 for Temp/Hum sensor connected to TX_Unit 1
#define WIND_OutUnit     0   // 0 for Wind instruments connected to TX_Unit 0, 1 for TX_Unit 1
#define RAIN_OutUnit     0   // 0 for Rain Gauge connected to TX_Unit 0, 1 for TX_Unit 1, 3 for Auriol RF Rain Gauge
// ---- Define the source of your main Solar / UV sensores
#define SRUV_OutUnit     0   // 0 for Solar Rad / UV sensors connected to TX_Unit 0, 1 for TX_Unit1, 9 for not used
// ---- Define installed Solar / UV Sensors
#define Solar_Sensor     1   // 0 for not present; 1 for present
#define UV_Sensor        1   // 0 for not present; 1 for present
#define UV_Transmission 10   // UV Transmission percentage of UV sensor cover material
//   Extra Sensors Settings and Mapping
// ---- Define the source and sensor number of each of the seven extra sensors, insert 9 if not used.
// ---- Source 0 (up to 3) means TX unit0, 1 means TX unit1... (sensor type SHT21 or HTU21D is number 0, sensor type SHT1x or DHT22 is number 1)
// ---- Source 6 is for OneWire sensors
// ---- Source 7 is for BIOS Sensor (Only Temp is get)
// ---- Source 8 is for Dust Density sensor. 0 is Temperature / Humidity, 1 is Dust Density / AQI
// ---- First field = Sensor source, Second field = Sensor number (0 or 1 for TX units)
// ---- Example:
// ----                          ES0   ES1   ES2   ES3   ES4   ES5   ES6
//#define ExtraSensors_Source { {0,1},{1,1},{9,9},{6,3},{9,9},{9,9},{9,9} }
//               {0,1} - First extra sensor (ES0), will be sensor 1 from TX unit0
//               {1,1} - Second extra sensor (ES1), will be sensor 1 from TX unit1
//               {9,9} - Third extra sensor (ES2), not used - not mapped
//               {6,3} - Fourth extra sensor (ES3), will be OneWire sensor number 3 (OneWire sensors are numbered from 0 to 3)
//-----                        ES0   ES1   ES2   ES3   ES4   ES5   ES6
#define ExtraSensors_Source { {9,9},{9,9},{9,9},{9,9},{9,9},{9,9},{9,9} }
// ---- Define personalized names for each Extra sensor. Attention, maximum 8 chars
#define ExtraSensor1_Name "SENSOR 1"
#define ExtraSensor2_Name "SENSOR 2"
#define ExtraSensor3_Name "SENSOR 3"
#define ExtraSensor4_Name "SENSOR 4"
#define ExtraSensor5_Name "SENSOR 5"
#define ExtraSensor6_Name "SENSOR 6"
#define ExtraSensor7_Name "SENSOR 7"
//   BIOS soil moisture sensor settings
// ---- Please use the included BIOS_ID_Scanner sketch to find you BIOS Device ID
#define BiosSensor_ID 0   // Device ID in HEX format, or 0 not used
//   Soil / Leaf Interface Settings and Sensors Mapping
//   (The mapping logic is the same than used with the Extra Sensors)
// 0 = Soil Leaf Interface not used
// 1 = Soil Leaf Interface connected to a TX unit
#define SoilLeaf_Interface  0   // 0, 1,
// ---- For Soil & Leaf data from SoilLeaf_Interface wired to a TX unit, use TX Unit number as source
// ---- For BIOS Soil Temp / Moisture use 7 as source
// ---- To disable use 9 in both fields
//                                 S1    S2    S3    S4
#define SoilTempSensors_Source  { {9,9},{9,9},{9,9},{9,9} }
#define LeafTempSensors_Source  { {9,9},{9,9},{9,9},{9,9} }
#define SoilMoistSensors_Source { {9,9},{9,9},{9,9},{9,9} }
#define LeafWetSensors_Source   { {9,9},{9,9},{9,9},{9,9} }
// ---- Define personalized names for each Soil and Leaf sensor. Attention, maximum 8 chars
#define SoilSensor1_Name "Solo Frt"
#define SoilSensor2_Name "-"
#define SoilSensor3_Name "-"
#define SoilSensor4_Name "LagoAgua"
#define LeafSensor1_Name "Folhas  "
#define LeafSensor2_Name "1"
#define LeafSensor3_Name "2"
#define LeafSensor4_Name "4"
// Define VWC calculation method
// Method 1 applies only for VH400 soil moisture sensor
// METHOD 1 - Conversion from voltage to VWC (volumetric water content) is done using the piecewise regressions provided by the manufacturer
// at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml
// METHOD 2 - Used for any sensor which have a linear output between voltage and VWC (0V=0VWC, maxV=100VWC) .
#define VWC_CalcMethod 1
// Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface
// Default value for Decagon Devices LWS Leaf Wetness Sensor (5V power): Max. Output Voltage - 1400mV (max wetness), Min Output Voltage - 530mV (dry)
//                                                  ADC1  ADC2  ADC3  ADC4
const unsigned int AnalogSensor_MaxVoltOut[4]   = { 3000, 1395, 5000, 5000 };    // Values in miliVolts
const unsigned int AnalogSensor_MinVoltOut[4]   = {    0,  530,    0,    0 };
//   Broadacasting settings for Wireless Display Units
#define Relay_Data       1   // 0= Disables Data Relay, 1= Enables Data Relay
//   Davis compatible Data Logger Settings
#define Logger_Enable    1   // 0= Disable 1= Enable
byte ARCHIVE_PERIOD  =   5;  // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30)
//   Easyweather format data Output
#define Easyweather_Out  0   // 0= Disable (defaut) 1= Enable
//   Internet Settings
#define Enable_Internet     0                       // 1= Enable Internet connection, 0= Disable
#define SSID        "ASUS"
#define PASSWORD    "my wi fi password"
#define Enable_NTP          1                        // 1= Enable Sync time with NTP servers, 0= Disable
// NTP Servers:
#define timeServer "137.92.140.80"                  // NTP University of Canberra
//#define timeServer "193.79.237.14"                 // ntp1.nl.net NTP server
#define Enable_WUupload     0                        // 1= Enable upload to Wunderground,     0= Disable
#define WUupload_period     3                        // Period in minutes between uploads to WU (avoid use less than 3 minutes)
#define WUupload_InTemp     0                        // 1= Enable upload of Inside Temperature / Humidity, 0= Disable
// ---- Wunderground Personal Data
#define WUNDERGROUND_STATION_ID "INORTHWA13"         // Weather Underground station ID
#define WUNDERGROUND_PWD        "WU Password"         // Weather Underground password
//   Enable / Disable GPIO routines - General Purpose Input / Output ports
#define UseGPIO  1   // 0=Disable, 1= Enable
//   Test Mode : Never run a live system in test mode
#define TestMode    false    // false= Normal working mode, true= Test mode only (no logger, no usb connection)
//   Hardware settings
// ---- Define LCD I2C address
// Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display
// Default address will work most of the times!
#define LCD_I2C_Address 0x27
//   SHT31 I2C Address - Default address will work most of the times!
#define SHT31_address 0x44       // Default value is 0x44, but it can be changed to 0x45
//   Presure Sensor Address (no need to change)
//#define BMP085_ADDRESS 0x77    // I2C address of BMP085 or BMP180
//   Debug helper
//#define PRINT_DEBUG_NTP_UPDATE    // Prints to serial monitor messages related to sync time with NTP server
//#define PRINT_DEBUG_WU_UPLOAD     // Prints to serial monitor messages related to Weather Underground upload.
//#define PRINT_DEBUG_AURIOL
//#define PRINT_DEBUG_BIOS
//     End of user configurable options
