31-12-2022, 14:31
(31-12-2022, 06:43)mikeyk Wrote: Hi,
I'm having the same issue with date, but it appears to be that the 1.6.21 version won't work on 64bit systems.
I had to use 1.8.6, otherwise I received this error "Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++: bad CPU type in executable"
Is there any other workaround, or something that can be updated to allow an AVR version greater than 1.6.21 ?
Cheers,
Michael
Hi Michael,
I just uploaded the firmware for the RX unit of the Pro2+ series, PCB even v1.3. I was working on a laptop with Windows 10 64b, Arduino IDE v2.0.3,
AVR board manager v1.6.21 and absolutely no problems. You can freely upgrade or downgrade that AVR board manager as needed.
But on that occasion I noticed one issue that I now believe is confirmed and appears in all firmware versions I've tried. I'm just not sure yet
if this problem is only related to my LAN setup and therefore only my problem.
The point is that the NTP protocol, which helps in setting and synchronizing the time, has stopped working for me on the RX units
of the Pro2+ series. In the default configuration, you do not set anything, the pool.ntp.org server set is used. And this stopped working for me.
However, just use the IP address of any (nearest) NTP server and everything works without problems (e.g. in my case 195.113.144.238 = tak.cesnet.cz).
It could potentially be a DNS service issue on my network, but it only shows up on the RX unit Pro2+. And that's weird.
Maybe a topic for you to try.
